Hey guys i just put in my new esc. for my acedeck 2wd and ran into a issue if anyone has experience with motors is their steps i can take to solve this problem or do i have to completely get new motors and a esc
Did you make sure to program both sides of esc?
Try swapping the motors around. I just bought a 9028 esc and one side blew on detection.
Try the motor not working on the other motor cable see if it spins or not.
@me_ashman i just tried the motor on the side that’s not working on the side that is working it spins and when i use the motor from the side that is spin to the other it doesn’t spin
Spinning
That means it’s an ESC issue, the motor is fine. Is it a programmable ESC? If yes, redo the motor detection. If not, check if all internal connection are good and if yes, claim warranty on that ESC.
Yeah i will just claim the warranty but before i do that i will check all the connections
Yeah I think they use the same 9028 esc. They will probably send a replacement. Easy swap out
