Hill Climb Board | Trampa hollypro 35° | MBS F5 Bindings | Trucks Mbs Matrix I | Metal top truck | Jantes Rockstar pro | Overion Matrix metal mounts | Dual Overion 130kv 3500w | chain drive10x42 | FocBox Unity | flipsky VX2/Lipo 12S 12A/MaxCase MAX235H105S.001
Heat issue while climbing solved with new motors and Focbox unity, Trampa Deck had more POP, Metal motor mounts and Top metal trucks mounts security, i found a lowcost pelicase-like, and a vx2 remote. F5 bindings to hang on the board
Overion stuff is great, really, motors are powerfull and metal motor mounts designed for Matrix I trucks fit perfectly, and they are not the easiest trucks to be motor mounted i think. Result is a rock solid system.
I have the matrix 1’s as well. Was considering upgrading, but I wasn’t aware of these mounts! Do you like the matrix ones? Have you compared them to the 2’s? Wondering if the upgrade is worth it.
not affraid of water/mud ?
but you’re right, the focbox looks really great like that, you sould try to paint black some part of the pelicase as well to recall the unity dissipators
i try both of them, same good result, no need to change truck, the only difference was the matrix II accept metal top truck. but with correct spacer matrix I too, and i prefer Matrix I design.
