Currently charging my 10S8P battery with a 2A charger, so that is taking a while. Looking for suggestions or to buy if somebody has any for sale. I think around 6-10A would be perfect, but I am not sure which models are reliable, and if there are any that are not too bulky or heavy, as I have to carry it with me during the day.
yzpower or OEM’s from that factory are pretty decent for the low price. I’ve got 2 of them. My only complaint is the cooling fans only turn on when there’s a load on the charger. So when it’s done charging they just shut off, but the enclosure is still pretty warm. Would prefer them to just be on all the time.
8 amp example here. https://www.ebay.com/itm/Yzpower-42V-8A-Lithium-Battery-Charger-for-36V-5A-Li-ion-Ebike-Power-Tools/283494884845?hash=item42019ca5ed:g:XKUAAOSwAQBaufFA
thx for the love @anon54720240
OP lemme know if u want… 2 left… you should be full in a few hrs not days on 8p lol… if you need some wiring or whatever lemme know and I can drop it in the box
Looks great but the postage to UK is definitely going to make it too expensive compared to getting it from China
Those are all 12s but you can perfect buy them in 10s
agreed =) you should add yur location to your profile so people know yur general area.
If the load is off then there isn’t a reason to keep the fan on, it will just continue to get cooler slowly. I don’t see the benefit.
That’s what I need for 8P 30Q’s. Thanks, @pjotr47!
What type of connector would you recommend? (I will of course get a matching panel mount one for the board)
I use xt60 in my trampa.
You have also some special high current connectors on Ali.
I use a xlr on a 8A charger
xlr all the things
And diode/fuse it
If you want to charge at 15amp for them huge packs
