Hi Everyone :) Could use some help if you got a min..
Hello Everyone,
I’m new here and glad to be here! I want to say thank you to everyone for your time and input here on the forum. All the info has been a big help. I’m hoping you guys can give me a hand with something I’m having trouble figuring out.
I recently installed 2 “FSESC 75200 v2 alu PRO” controllers to my build. Just the other day it was turned on (I think) and had my 3 ignite wires exposed and accidently shorted BAT+IGN to GND :frowning: . If I am mistaking and it wasn’t turned on then I would assume it was just GND to BAT+ because it did spark good. But since the controller wont come on at all after the incident i think it was BAT+IGN . The second controller is not very accessible, or Id open it and use it to try and figure it out. But It still Powers on fine connected through the main controller via uart so I believe the 5v rail is working properly. BTW I replaced the IGNITE fuse and still no light, feedback, or BT from her. oh and the GND that i shorted wasent the one from the header with the other 2 wires.
So to the point. I’m trying to find a schematic for this esc but am unable to so far. Does anyone have access to one? Or of a similar make with the same ignite circuit? Or does anyone have any input that might help? Seeing how the ignite circuit is built would help me understand what happened. A schematic of the whole controller on hand would be tits.
In advanced Thank You :slight_smile: ,
Random-E
I dont have any suggestions for your specific issue unfortunately.
Two general suggestions to help get more visibility on this question:
  1. Change your title to something that actually describes the issue and the hardware you have. That will make people more likely to click.
  2. Post this question in the beginner question thread.
