Help with VESC tool
These motors can typically go to at least 100A “motor max” and you probably want like -75A motor min, that number controls how strong the brakes are at LOWer speeds
For “battery min” or regen, you probably want about -15A per ESC, that controls how strong the brakes are at HIGHer speeds
as for battery max:
What size wire is going from your battery to the ESC?
Who built the battery, or how are the series connections done, with what size wire/nickel/etc?
Are you bypassing the BMS for discharge? (like this)
In absence of additional information, I’d set battery max at 41A per ESC but you may be able to go higher with additional information.
