Hey guys, I think I did something stupid, but still don’t know what i did, so I just build a new battery for the skate and everything was working perfect i tested everything and changed a few settings in the metr pro app then tided up one zip tie and now both vesc’s are not turning on anymore, they just start to quietly bep or whistle, I have a feeling that something is burned but it’s weird because there was no shortage and the battery is still working normaly, but the vesc’s just don’t turn on anymore, could I make a shortage with those rods that I put the vesc on so ghat It doesn’t move around, it’s bolted to the aluminium plate but I checked with multimeter if there is any contact and it wasn’t so any suggestions what is happening?
is the white to yellow wire just twisted and soldered left exposed?
Don’t try to operate the motors until you check the motor settings. You may have accidentally erased everything. Did you believe VESC Tool when it tried to talk you into upgrading? Or did you only use metr?
no, thats already wrapped up
the board was working everything was properly setup I was riding that board with other battery but i didn’t touch the settings, i just plugged it in to the vesc tool to read the motors again and that’s it, and now it doesn’t turn anymore
Check the harness on the power button. Looks a little tight.
Did you have some kind of antispark plug or switch? I had a vesc refuse to turn on when not using an antispark
yes I have antispark switch and it is not turning on and I even tried with power supply not battery and still nothing
