Help with Flipsky fsesc6.6 plus and VX2 Remote
Thanks Tim, I will have to do a little more research on that. I am familiar with setting motor currents and the ABS overcurrent. Braking… understood.
When it comes to millisecond times and percentage curves, that I don’t know.
My motor has 14 pole pairs for that Flipsky 7384, I know that. Looks like I have a little reading to do. Thank you for all of your input!
When I have had similar issues I just downgraded my vesc back to older program and it worked like a champ again.
So… I ran in to something similar running a newer version of VESC.
I personally don’t think it’s an issue with the new VESC version, but extra features that change when updating the version.
If it doesn’t work, try swapping the TX/RX pins on the connector. Just use a blade to lift the plastic so the pin can release.
  1. Make sure the VESC are on different ID’s
  2. APP Settings > General
  3. Primary VESC set “APP to Use” as UART
  4. Second VESC set “APP to Use” as No App
  5. Set “Pairing Done” and “Enable Permanent UART” to True
  6. Enable the Can Message Rate Status
As soon as I made these changes, both motors worked.
