Help needed - twitchy throttle release
I have been having an issue with my board recently. Mainly, every time I let off the throttle (especially when I’m going down hill), my board starts “twitching” almost as if I’m getting speed wobbles but it feels more like the motors are twitching. This does not happen when I hit the breaks, just in the transition from low throttle to no throttle.
I am using a MakerX DV6s and puck 2. I have double checked for matching throttle curve, input mapping, and ramp times. I have also tried adjusting the ramp times and how fast I let off the throttle. Nothing has helped.
Does anybody know why this is happening? Is there some setting I should change? Possibly just a trucks/balance issue?
Thanks in advance.
I’ve experienced this feeling you’re describing when hitting thermal limits. Could it be that?
Due to an assumed 15% value between when thermal limits affect throttle than breaks, this would describe such experiences.
It’s somewhat common for thermal limit settings to be misinterpreted. There’s better information on it, but basically you take the value for temperature limit, subtract the value assigned for the ambient temperature, then take 15% of that. Subtract that amount off the temp limit value. Thats actually when the temp limit cutout starts to apply for the throttle.
So, if motor temp limit start value is 85 degrees, you lose throttle at around 75 degrees. This would happen to one motor before the other, and things start to feel twitchy.
Definitely wouldn’t be that. I have my temp cutoffs super high and the spot where I have the most trouble is within a quarter mile of the start of my commute. There’s a chance that I have a temp sensor out but I’ll have to do some digging to check.
Sounds like a weird one. If it’s just started doing it, then it’s probably not settings. I doubt they would change by themselves, not impossible, but I would think very unlikely.
The puck 2 is hall sensor right? So it’s probably not a dodgy pot in the remote. You could try a different remote or try changing it to LH operating and looking for differences, but the feeling you describe sounds more like individual motors dropping out momentarily so it’s not likely the remote.
After I read your post better, I agree. It’s not likely thermal. However, the description of how it rides reminded me of exactly how I felt when I had both overheating ESC’s as well as for motors. It was quite off putting. Vesctool records peak temperatures, so even if a sensors playing up - you would see evidence.
I’d be checking all my wiring, including the solder in the phase connections of the motors. Hall sensors are only relevant at very low speeds, so I doubt they’re relevant but im potentially wrong.
This weekend I found a flipsky motor with a hall sensor that was never soldered from new and causing intermittent problems, so it’s probably good to keep an open mind towards any type of fault including a fault with the ESC.
Another idea, perhaps disable one motor challenel at a time and use in one wheel drive. See if you can narrow the fault down to one of the two sides that way. From there, you could determine if it’s motor or ESC related. I’m not sure what you might find.
If you haven’t already, now would be the time to reduce the default fault recovery time of both channels from 500ms to about 80ms, I think that’s the universally accepted figure and doing so has saved my arse a few times.
Have you checked the vesc fault log after/during a ride when it happens?
I’ll bet you’re getting overcurrent faults likely from a main power connection being loose or faulty
Will try the one wheel drive idea. I already had the fault recovery time at 80ms.
I think that its always done this. I just got back into riding after a long hiatus and I’m getting comfortable going faster now so its just a bit more unnerving. It feels a lot worse at higher speeds.
I have done a few logs while its happened but there weren’t any faults. I’ll start trying to trigger it as much as I can while riding to see if I can figure anything out.
Kinda sounds like sensor weirdness, specifically the “sensorless ERPM transition” setpoint.
I’ll try going senseless and see if it does anything. But the speed it happens is much higher than the transition speed.
