Hey guys. So I think I’ve learned a chunk about choosing a battery set up from all the awesome posts found here, I am however having trouble making a final decision on which direction to go. Here is my build details.
MBS comp 95, 8" wheels hybrid street and light offroad duty build using TB3680 190kv 80amp x 2 motors, Stormcore 60d. I live in a large spread out city, shooting for 60km range geared for 50km/h top speed.
Top mounted battery, max width dimensions of battery enclosure is approx 11.5" inches by 9", height can vary a bit, but hoping to keep it less than 5", thinner the better. The following options fit within my battery box size constraints. I’ve been using the 3dservisas calculator to run these numbers.
Option 1. 12s8p using 40t cells set up for 25amps max discharge per cell as I have read this battery tolerates this level better than the full 30amps. This gives me 200amps pack output, 32AH, 57 km/range, 49km/h speed, 34 ft/lbs torque.
Option 2. 12s8p using p42a cells. Gives me 360 amps on the pack, 33.6AH, 60.5km range, 49km/h speed, and 34 ft/lbs torque.
Option 3. 10s10p using t40 cells, Gives me 250 amps on the pack, 40AH, 60km range, 50km/h speed, 33 ft/lbs torque.
Option 4. 10s10p using p42a. 450 amps, 42AH, 63km range, 50km/h speed, 33 ft/lbs torque
Option 5. 10s14p using 30q. 280 amps, 42AH, 63km range, 50km/h and 33 ft/lbs torque
Option 6. 13s11p using 30q. 165 amps, 34AH, 65km range, 50km/h, 33 ft/lbs torque
Option 7. 12s14p using 30q. 210 amps, 42AH, 75km range, 50km/h, 34 ft/lbs torque
Some of these options are more desirable to me than others. The larger p-group options don’t make much sense to me because of the high cell count, but I’ve included every option I can think of that would fit the most power density into my given battery compartment space. I’m not too keen on building the battery pack higher above the deck, hoping for the most minimal looking enclosure possible. I have someone lined up to fabricate a fibreglass or carbon fibre enclosure once the battery is fully assembled. What do you think? Is there a cell I’m not considering? or a cell configuration that might work better? I’d prefer to run the cells with some headroom and range is also an important priority. Any feedback super appreciated, I’m spiralling into certain doom around this decision haha.
