I’m looking for some advice on motors for an electric mountainboard build. It’ll be dual motor with 8" pneumatic tires, a 12s5p p42a battery, and Maker-x DV6 Pro VESC. I’m not looking to go 50mph over logs, but I would like enough torque to haul my 220lbs self up decent hills.
The motors I’m currently looking at are:
Mboards 6368, which is my budget option and is a lot smaller than the others.
Flipsky 6384 140kv, this would be my top pick, except I’ve heard a lot about flipsky’s poor qc.
Torqueboards 6380, looks like a really solid motor, but I’m not sure if 190kv is low enough for my board.
With the DV6 Pro, you will have enough torque to haul you up any hill. I would recommend Flipsky BH 6384, those are tried and true. 170kv if you want some torque, 190kv if you want a bit more top end while sacrifice a bit of torque. I find that 170kv is sweet spot if you prefer torque. Or you can go all out and get a set of Reachers motors.
I’ve not had much luck with BH Flipsky 6384s when running high amps.
The weird whining sound at a particular RPM is one thing but I’ve had magnets slip in the housing on multiple motors. (I run with belts pretty tight though as a brake heavy and been told this isnt good for the design of these motors).
My recommendation is the Radium Performance 6385s.
Edit: Been running a set of the Radiums on my commuter flawlessy for easily double the kms the Flipsky motors lasted on the same setup.
IMO the only connectors that matter on a motor are the ones on the sensor wires. Those are more annoying to change since you need a crimping tool, new metal ends, and then the plastic housing bit. For phase wires you just solder off the default ones and solder on new ones. No need for specific tools (everyone should have an iron and if they don’t then at least it is a tool with a ton of uses).
Oh and add in heat shrink wrap if the connectors used don’t have a built in plastic shield/ cover or if you just hate fucking with that piece.
For people who don’t want to mess with crimping pins you can get pre-crimped connectors on eBay with like 7" of wire hanging off in various JST sizes from 2p to 10p.
