Gummies without the hubs?
3dserivas 3:1, I think it’s too small of a ratio for large pneumies, oh well it’s good enough as it is, also not sure if bergs fit my superstar hubs, if they did I would lose range and urethane feel. Just wanted to see if an upgraded gummies could be done because they have their cons (feeling lots of the road). Wanted to see so there could be a good alternative made with much thicker urethane like a regular wheel to fit on a setup like mine for those who want the all the pros of urethane.
They’re just beautiful trucks all around.
the SS drive I presume? not sure about your version but fitting bergmeisters with an adapter might be possible. You should reach out to 3dservisas. At least for the new version there is an option to run with bergs
The gummies are flat on one side, been playing with the idea to stick two of them together somehow. You’d have to do some customization to the hub to get it that wide tho :smiley:
that would look massively badass :thinking:
you could somehow extend the axles and put two hubs+ gummies on one axle.
