My mans dexter
You beat me to it
THESE ARE NOT 110 guys. These are 74a 100mm. Same duro as the artic blue but a smaller sizeâŚand black
Câmon man itâs 2020. We ainât like that anymore
Only 52mm contact patch
Same as the red boas I believe
Theyâre not, boaâs are wider.
My bad, I must be thinking of another wheel
Same as the abec 97 wheels in width. I might pull the trigger and try these out! Have some 38t pullies just waiting for a purpose again
19$ - 90mm set of 80a abec hub clone wheels after discount ârelief15â applied (22$ typically)
I do not know how skateshredâs thane holds up compared to other wheels. They just looked like a good deal when I checked out skate-shreds website after Briman posted the discount code.
They may be âtoo good to be trueâ, and many donât go that low in wheel diameter, but they are a very cheap option if on a budget.
Clone cores, not gonna work with normal abec pulleyâs. Good price tho.
Will edit, thx.
No? Why shouldnât they work with abec pulleys if the core is cloned?
There are two ABEC core variants: âOriginalâ and âCloneâ. Clone pulleys will fit Original wheels loosely (although shrink wrap helps mitigate), but Original pulleys wonât fit into Clone wheels.
But Clone pulleys fit Clone ABEC wheels?
Yes, and original pulleys fit original wheels. There are two variations of Kegel cores, too. Itâs ANARCHY.
I got these wheels:
And the motor mounting kit from dickyhoâŚ
Do you think the pulley will fit the wheel?
Yeah, my first powered wheels where skateshred 90mm clones and dickyho gear. The skateshred thane is typical chinathane. Pretty hard, doesnât chunk at all. Even 97mm chinathane feels worse than 85mm cags. Not at all unliveable though, your feet will just hurt more.
do you know if the 120mm cloudwheels (original, not the new discovery cores) are âcloneâ or âoriginalâ cores?
I have elofty DD adapter that fits my cloudwheels perfectly, but idk if theyâll work with genuine abec 107âs that i just got
Thanks!
I donât have a set in hand, but I believe theyâre going to a clone fit because the spokes are definitely thicker. I can confirm later this week when they get here.
Original cloudwheels are abec core. new discovery cloudwheels are thicker so probably clone core, but I suppose there is a small chance they could be different from the clone core too.
