The test looks promising. I’m currently waiting to see if someone has done some heavy test rides with these. My retro still works very well.
I’ve been using the same BKB BT module on a Maker X DV4 but the RT data for top speed is way out!?? Is that the case for you?
Moved to PM
why are you using two separate connections to vesc tool? isn’t it closer to realworld to drive it in can-fwd?
ever busted one of your USB ports?
I’m starting install on an emtb, one thing I would say is the 10awg for phase wires are a little over the top.
None of the motors I use have any larger than 12awg. This would make neat installs a little easier I think if these were 12awg.
If this is your largest complaint I’m really excited to drop mine in a build.
For them to be 10awg; now I’m really curious on their real world performance.
Yep, it looks well made and solid.
Lovely if it had a built in anti-spark switch too.
I think APS should be added in BMS. So it can control the overall control.
This feature will be available on our upcoming BMS.
your dv6 is promising for emtb with 8inch tire but at 12s on foc mode and set on 100A on each side (dual) i am not so sure if the drv chip will not fry. so for this year i will wait because snow is coming anyway and next spring i will check this post again to see if your dv6 is bullet proof for etmb application
Had mine on the bench running with 2nd gen elofty DD no stutter with 5.1 fw rock solid even with full power. Out performs my flipshite 6 dual. voltage reading via UART also more stable. Very nice ESC my 2nd favourite next to my stormy. Won’t be the last one I buy.
Details on your Dyno please
And the bullets are stupid huge.
Is one motor on each ESC running as a load for the other motor?
Just a simple FOC open loop test.
I will conduct a high-speed and high-load test soon.
Anybody had chosen standard shipping? I did for about a month and still no idea where it is or when it will arrive. Anybody had better luck with it?
I think I did; I received mine in the mail only 2 days ago.
Good to know. Hopefully it will also arrive soon.
