Havenāt received it yet? Your order shows that it has been signed.
@elitejarcool (Imperium boards) may be a quicker local source, theyāre in stock now. I donāt have any personal experience purchasing from them but theyāve been around for a while.
Imperium is 100% legit. @elitejarcool is a solid member of the aus diy community.
@JeffyJ already has the escs. Heās waiting on the @torqueboards direct drives.
I can see how my comment may have been confusing. My bad. As glyphics mentioned I do indeed have the DV6s. Iām waiting on my Torqueboards order. Sorry for confusion.
No worries, all g.
Same, Iāve ordered blue TB 110ās but theyāre not even in stock
Come on Dex pls fulfill us esk8 addicts down under!
Absolutely, Iāll be purchasing many parts from him pretty soon, DV6, VX2 pro, maybe some motors. Having legit local sellers makes a world of difference!
results?
100A can run stably.
Was that 100a only on one side though?
With two motors running it will get heat soaked faster
Dual test will be soon
Hi,
trying to gather the parts for my setup (8" tires, gearing 9/35 on a Emtb) and seriously considering the DV6 but need advice on the rest.
Will it be ok with :
- 2 flipsky 6384 ? or should i go down to 6374
- VX2 pro remote
- Flipsky 200a antispark ? maker x one is XT60 when DV6 is XT90 as the rest of my setup.
- a compatible BT module (NT51 from flipsky ? so i can source all the rest from them)
thanks guys.
Grab a METR for bluetooth, theyāre pricey but you wont regret it.
yeah but apparently not vesctool app compatible
Metr has itās own app that is amazingā¦
BTW I would wait some more for CAN metr version to be released⦠should be soon, at least I hope soā¦
Metr is vesc tool mobile compatible.
Wait what⦠screenshot?
iām not sure if iām looking at a tiny ESC or at a hugeass hand
Both sides running together for a duration of 54 seconds, and the temperature had slowly gone up to 78 degrees. That must be a darn good heat-sink!
thatās pretty impressive, well done
@rusins Seems to be more than enough for general hard accelerations and sustained high current. Iām considering this for my eventual mountainboard build haha
Iāve been using the BKB NRF module with the vesc tool app. Works well
