I tried 5.2 and 6.0 and the issue persists. The only way I could make it better was to measure offsets in FOC tab (FW 5.3) and THEN perform detection. Motors sound weird at low duty cycles and after picking up speed they become smooth again.
Please keep the discussion in this thread about the Maker-x DV6.
Thanks for the reminder, I will delete the download link right away!
THX a lot for taking action!
Vedder wants to assure that people actually get what they are looking for.
If VESC-Tool would be available from multiple sources without quality control, users get confused and it is also not guaranteed that they are all 100% the same software. So the only way to handle it is having one source distributing the software under the Vedder brand. Others simply need to use their own brand.
It’s GPL code, you could do a better job with license representation/links to original source, but you are allowed to rehost the unmodified or modified code. In fact the entire point of open source is to publish changes & improvements you’ve made.
Frank is not the author, he is harassing you because you sell a competing product. He has an established history of this behavior. Just ignore him.
We give a dam about someone selling hardware as long as the manufacturer sticks to the GPL and TM Policies. Everyone is welcome to produce HW and sell it and the FWs are even added to VESC-Tool!
Stormcore, raiden, FOCers, U-Box, you name it…
May I ask how to add firmware to VESC tool ![]()
Create a GitHub account, fork the appropriate repository (VESC-TOOL and/or BLDC firmware), publish your code changes to your fork and then create a Pull Request to the upstream repo.
If you have any questions or need any assistance in getting this setup, shoot me a PM, I’m happy to help.
Great! Thank you
Will it have custom firmware? Or 75/300
Via pull request is the best option.
Make sure your offer is GPL compliant
Make sure you stick to Vedders TM policies.
Have a close look at your Website!
Make sure to test the fw frequently, in combination with the BETA- Tool. Vedder won’t have time for that.
If possible try to avoid the need for special FW. To avoid fw clutter and confusion.
second this.
never had problems with orders or something.
Just wanted to drop by and mention that @YUTW123 offered my friend (the one with the broken sensor port) proper help and warranty. In the end we managed to fix his DV6 and we just came back from pumping 100 motor amps per side and it took it like a champ. Thanks!!
We are still waiting on some new motors to check out the other one (negative current on forward inputs) though, will report back when we have some more data.
please make it so it works with momentary switch instead of latching switch
Are they 12awg wires? ![]()
Will the antispark support roll-to-start?
Yes 12 awg,, because of the small size
not support
