I bought it directly from makerx-tech.com. $260$
Motor current can be greater than battery current, it’s just that at a certain speed battery current will start limiting your output power. So you could test it, just at low speeds
No, Pro is still built on V6. We just changed the mos so that it can handle a larger current. And in the firmware, the maximum motor current is limited to 180A (the default is 120A) and the shunt is changed to 0.5MRx2 (previously 1MRx2), which can reduce heat generation.
A small preview: Dual 100V 200A (based on 100250)ESC is being designed. ![]()
DAMN
Bruh catch me building a minibike @PropulsionBoards I’m coming for yours
I know this is the cart driving the horse here but I’d be much, much more inclined to swap over to one of these if I could tap a different mounting pattern into the bottom plate (y’know, the usual Unity/Xenith/SC pattern).
Is that possible for me to do? Is that possible for you to do even, @YUTW123, maybe on a future revision?
Edit: Just noticed the GH1.25 JSTs and
went my hopes for standardisation
Dv6 and Dv6 pro both use JST PH(?)2.00 standard VESC connector size. Just the mini foc and mini foc plus use JST GH1.25.
Ah! I saw it listed in the specs and assumed it was the same.
Looks like it only applies to the CAN port?
Yeah just the CAN port, in the ESC’s defence 4WD riders make up probably less than 1% of riders.
Despite it being different, it is the superior connector. Especially for a CAN connection
I kinda wish all JST connections on VESCs were locking connectors, just not so small since the wire has to be microscopic but for the CAN port, I’ll allow it.
But can anyone tell me whether it’s safe to drill & tap new mounting holes in the base of the ‘cooling box’?
Well mine only made it 250 miles running at 60amps Max… Sucks I had really high hopes for makerx
send em an email. Which esc did you have?
Dv6 I bought it on the pre sale. I bought a second one since that I’ll use in the meantime. Ordered a unity thinking they are better but then read all the problems. Hopefully mines good
The circuit has been upgraded several times and its performance is now very stable.
Please contact us info@makerx-tech.com to deal with after-sales problems.
As long as you take the esc out first I don’t see an issue.
@SabreDynamics has kindly offered to modify my 3DS heatsink for me instead, which is probably the better solution. Thanks very much for getting back to me though.
+1 mine is very solid, been running it for several hundred miles of abuse, no issues. @Juicehall give em an email and they’ll likely sort it out for you
