Ahoi mateys!
I am getting increasingly sick of the placement of the valves on the Hyperrims which I fitted to my Nazaré.
I like the looks and width but pumping up the tires is a nightmare.
It’s ok to do on the front since the rear piece is quite open but on the back the wheel pulley is in the way.
I have to loosen the belt and remove the whole wheel to pump up the tires.
I was thinking of getting different rims with better valve placement but I do not like the deep dish and offset e-toxx ones and landsurf ones I like are out of stock.
Or is there a valve longer make thingy I can screw on the valves which won’t let all the air out when screwing them on and off?
I tried various things, I have a very good standing pump but that one has this head with the lever and I have a small hand held compressor, that has screw on tubes, unfortunately there’s no valve at both ends and there’s no way I can screw on the tube and then the compressor.
Hmm… having a hard time imagining without a picture. But
This guy is a dual stage, so you lose no air when unscrewing from the tire valve.
It takes me about 30-60seconds per 8x2 tire to fill to 35 psi (I think that’s what I always used? Been a little bit)
That’s definitely slightly more time than other options, but it’s not like we find ourselves filling our tubes all the time so I think it’s very reasonable.
If something like this wouldn’t help the issues you’re having, I think your best option as others have mentioned are valve extenders, & then different rims all together.
This is smaller & more compact than the skinny tall soda cans white claw & shit comes in now. Honestly 25% the size aside from the pressure gauge.
