BN Drive works great for me. But highly recommend getting straight cuts, helical will cause can movement in your motors later on.
I have a nazare supersport. I think the straight cut gears are only for 8mm axle size, so you’ll need to replace the motors if your current motors have 10mm axles, and you want to use straight cuts.
How do you like your Newbee drive so far? What do y’all think the biggest differences are between the Newbee Gear Drive versus the Boardnamics Gear Drive?
What would you recommend for new motors to go with the BN gear drive straight cut gears with 8mm motor shaft pinions?
The 4gs drives have been great. Very smooth, very quiet.
getchoself @Skyart reachers if you’re in the US
best in the BIZ, can handle more amps than others
