Fuse for charging port
Hi, what kind of fuse charging port for 70+ volt
most are for 32 and 58volts.
80v blade fuses are out there but kinda suck for availability. Mouser and digikey are the best sources i have found.
https://www.mouser.com/ProductDetail/Littelfuse/166.7000.5202?qs=516rMiIh%2F3KQn6o5%2FRvo%2Fg%3D%3D
Should be able to get blade type fuses up to about 25a then over 25a switching to a bolt on marine fuse that has some cross use in solar installations is your best bet.
If you are North America or Europe or getting international shipping is easier from the usa or eu will determine which is better for price
