Hi all, I am at a loss with my DIY mini board. When accelerating or braking under load the board almost instantly cuts out. When I plug it in, VESC tool shows a “FAULT_CODE_BOOTING_FROM_WATCHDOG_RESET” error. The attached image shows the error in VESC_Tool.
The fault is only while accelerating or braking under load, doesn’t happen during detection or while spinning up motor on the bench. I have tried a ton of different motor/battery current settings and the error persists regardless of how low/high the current is set at. Voltage settings are correct.
If anyone has any ideas, suggestions, or comments I would love to hear them. I’m really struggling to find a solution to this issue!
Full specs:
EVE 25P 18650 10s2p pack with Daly BMS (charge only)
Flipsky FSESC 4.12 ESC (loop key to turn on)
Pre-loaded 5.2 firmware
Flipsky VX1 Remote & Receiver
Single Flipsky 6354 140KV motor
MBoards 16t/36t pulley kit
3D Printed PETG enclosure
VESC_Tool Settings:
Battery max Discharge: 40A
Battery max Charge: -8A
Absolute Max Current: 120A
Motor Max Discharge/Charge: about 45A/-45A (settings from detection)
Things I’ve (unsuccessfully) tried:
-Changing battery/motor current values - Flipsky support confirmed they are correct
-Replaced the 140KV 6354 motor
-Tried brand new replacement FSESC 4.12 in case first one was damaged
-Halving observer gain in VESC tool
-Switching from UART to PPM remote control
-Shielding VESC from possible EMFs caused by power/phase wires
-Decoupling capacitor between 5v and ground on receiver to remove noise from power supply
-Relocate antenna to top side of board to remove possibility of interference
-Tried BLDC instead of FOC mode
-Used VESC_Tool 3.00 for setup per Flipsky’s recommendation
