Can’t connect IMU to VESC. Please help. Thanks.
The connection seems correct. Check with the mpu6050, you should see a green led when you connect it. I have a bkb xenith + mpu6050
I think Flipsky Mini FSESC 4.20 can’t work with IMU.
That’s good your mpu6050 probably has a red led instead of green. Connect again the mpu6050, select app to use UART then select imu type mpu9x50 and then write app configuration.
Check this
https://www.reddit.com/r/DIYonewheel/comments/116iuxs/vesc_imu_questions/
Did you try the settings above? Also try changing sda with scl
I ordered Makerbase 75200 V2. This mini was for testing and it is not working in any settings and thanks for your time!
