What did you pack in yours?
i used lucasoil marine grease on the last set i did,
i’m also exploring using superlube at some point as well
I wonder what would happen with some red 'n tacky
should be a o good to use
i pack to cover both sides spin to pack it in, put seals on and spin a couple times to squeeze out excess
ceramic bearing isn’t made for anything that require high speed or taking impact. period. everything will “technically” work until it fail and try to kill u, like 3dp printed plastic rims.
In the lab I got one of those plastic syringes for pet meds and used it to grease the gears, works pretty well after you cut the tip off to be more open, just used a plastic butter knife to scoop from the big tube to the syringe
I bet it works just as well for bearings
Get cheap trucks with fracture prone axles, some printed hubs with really thin tires, and ceramic bearings… eskate Russian roulette
Thanks guys, I got my order cancelled.
cmon on, we already have fully 3dp wheels, who needs tire at this point. just 3dp everything
ABS hubs and TPU tires?
idk dude, ask that dr.e guy
Someone already printed a longboard deck, and we have printed enclosures and motor mounts, we just need printed trucks and we are good to go ![]()
This is the way, i use marine grease. pack em with it, 5k+ miles through rain salt and road grit
I remember the 3d printed truck prototypes from @CHAINMAILLEKID
its a go
Seeing an almost fully printed board would be hilarious
Nope.
if u know how to wind ur own motor:
Oh god the performance on that would be absolutely atrocious ![]()
we go for style point here ![]()
