You mean ordering from @torqueboards? The V6 brackets are discontinued unfortunately. The only ones available are the V7 which are longer and only fit the new 280mm CNC V7 trucks. I have the V6 220mm ones.
i think the two mounting hole on the sides of the other support bar is more accurate, although i don’t even know how many people are actually able to mount that, since a slightly wider pulley / pressfit would already push the motor mount too narrow to a point where the rectangle bar won’t fit
Here is a V7 setup on 218s, you can see that the rod is not used between clamps anymore but between motors mounts. It’s a bit too short for this use, you can see some threads holding it.
I have not assembled everything yet but it seems like it will fit with TB pulleys I have, maybe they are shorter ? I have the 220MM CNC, that could help too.
i think the support bar is made exactly just for the TB pulley, anything else is just guess work. that’s also why im not using it, once i install either my 3DS or trampa pulley, the support bar is unmountable
Hmm, have to figure out some sortof alternative then for 3DS pulleys. Back to work on CNC.
What’s the best way to replicate that rod thought? Drill and thread aluminum rod on cnc?
