bEsT EsC eVeRRrrrR~
Whoa you’ve had it happen while riding?!? I’ve only had it happen while the board was off.
Yes I had noticed weird issues yesterday but made it home fine. Thought it was the chains, and I re-aligned one of my motor sprockets thinking that was the problem but nope. Checked the app today and my settings reset so I fixed them; it worked fine; then 10 minutes later it switched and although I could have ridden it out, jumped off to great success.
I wonder if doing it through my PC would be better. Always done setup via bluetooth.
Also it seems like 80% of the time the app won’t let me apply settings. FFS.
check if your BT module is fully seated and operational
Just had this happen to me as well. Not during riding but between rides the Unity just lost all settings. I am using latest Unity FW. I wonder if this happens with VESC FW as well, or only Unity FW? Any input?
By any chance did you let the board auto time out?
Not purposefully, but I noticed that the roll to start was enabled, so I might have turned on the Unity when handling the board.
I also noticed that the VX2 is messing up all config saving when UART is enabled. So if I want to change configs, I first disable UART, save, then do my changes, save, and finally re-enable UART (and save). I am getting a Hoyt Puck today and moving to PPM. Maybe that helps as well.
