Howdy. I’ve been cleaning shop to set up for my next build, and I’ve got a few items I don’t have need for anymore. Most of this stuff was free to me, so it’s going to be mostly free to you. All items are $5 plus shipping (to USA lower 48)
From left to right:
- 165 mm meepo tires with moderate wear, matching inner tubes [DIBS’ED]
- white hubba hubs which are a bit dinged up, and have mounting lugs for BN M1AT drives on two rims, with bkb tires that have significant wear [DIBS’ED]
- an unused set of bkb tires with matching tubes, been sitting on the shelf for a couple years but still feel rubbery. [DIBS’ED]
- aluminum carry handle which installs as a 10 mm riser
This is an 8s brick pack built with BAK N21700CG cells, which came out of the 20s pack that I originally built for Orbital. That’s low discharge, 5Ah cells. The pack has maybe 20 cycles on it, and has been sitting indoors at 3.7 volts for 3 years. Capacity retention has not been tested.
I know there’s probably not a lot of people looking for an 8s energy pack, but hey it’s worth a shot. If nobody needs it I’m going to discharge it to zero and dispose.
