After over 12 months of riding and upgrading, I think my Fishbone is finally finished, so I figured it was about time I shared the build.
I was keen to build a comfortable, off-road board that could power up steep, rocky hills without having range anxiety.
Over the last year it’s gradually evolved, with most of the changes being upgrades to improve power, range and traction, as well as replacing the hubs and rear ESC enclosure after I destroyed the last ones.
I also modified the trucks and bushing adaptors to fit Riptide bushings, which gave me a wider choice to fine-tune the handling.
After plenty of riding, upgrading parts and trying different bushing setups, I’m pretty happy with where it is now.
Love the Z.mote for its smooth control, long battery life, and Voyage Megan for all its features.
DECK
Flow State Fishbone flex deck
Double-stack segmented enclosure
Custom 3D printed footstops
BATTERY
12S8P Samsung 50S
Capacity: 40 Ah
Energy: 1,728 Wh
Ennoid XLITE-12+ BMS
SF12 2-pin charge port
AUXILIARY BATTERY
12S5P Samsung 50G
Capacity: 25 Ah
Energy: 1,080 Wh
Omni Esk8 battery box
Omni Esk8 12s 100/10 A BMS
BATTERY CONFIGURATION
Main and auxiliary battery in parallel
Combined capacity: 65 Ah
Combined energy: 2,808 Wh
ESCS
Rear Flipsky Dual FSESC 6.7 200 A
16mm DPDT LED Pushbutton switch
Tinnie’s MTB ESC Box V3 Aluminium plate
Front Flipsky Dual Mini FSESC 6.7 140 A
Front anti-spark: Maytech MTS1810AS
Front MBoards heatsink
Voyage Megan Display
Flipsky Bluetooth module
Z.mote single-trigger remote
MOTORS
Rear: 2 × Flipsky 63100 140KV
Front: 2 × Flipsky 6374 140KV
TRUCKS
Acedeck Horizon suspension trucks
Linnpower Riptide Bushing Adapters
Riptide Lacroix bushings - 80a front - 75a rear
Lacroix Hypertruck Titanium Grubscrews
DRIVE TRAIN
Acedeck ELEMENT AT Gear Drive 11:44
Linnpower Next wheel hub adaptors
WHEELS
Linnpower Quick Release Wide 66 mm hubs
9" quick release rings
TRAMPA Mud-Plugger 225 x 65 mm tyres
LIGHTING
Acedeck Horizon LED headlight
adjustable converter / 9v
Linnpower tail light
5v buck converter
RIDE CHARACTERISTICS
Weight: 30 kg
Auxiliary battery: 6 kg
Rider Load: 98 kg
Top speed: 54 km/h
0-40 km/h: < 3s
Range: ~ 40 km
Range with Aux: ~ 60 km
Ride height: 170 mm
Clearance: 90 mm
Wheel base: 910 mm
Stance: 680 mm
Comfort: High
Stability: Medium
Agility: Medium
