The remote did not need a solution, it was perfect from the begining
So, you contact the company saying the problem and they never had the same issue? Very strange.
To be fair, flipsky should be able to tell you that your remote it’s working fine, that you only need to put your board on the floor or to give a load to the motors. But instead they acknowledge there is an issue, and then proceed to not give any solution.
I think this should be called VX2 troubleshooting, bc this simple “problem” had me scratching my head for two weeks, im pretty sure more people will find it useful in the future.
That’s how all remotes using current control behave, it is really more of a VESC behavior. (0% throttle = 0 amps, 100% throttle = max amps) Feeding 2 amps (~5% throttle) to the motors without load is enough to make it spin to max speed, but it does barely move when on load.
