Hey guys, I was wondering what to use for my flipsky vx1 remote. I was going to use PPM but in the manual, it says that I need to use UART if I want to reverse. I want my board to be like a boosted board (towards is forward, backward is the reverse, not break if you know what I mean). How can I get that? What should I use?
I don’t know if this information is relevant but I am using a dual 6354 setup and dual maytech vescs
Not exactly like it, I just like the way the remote works. This may be the default, but on my pre-built throttling backwards makes it come to a complete stop instead of moving in reverse.
Yes. The receivers are the same. The only thing different is cable. If you have a PWM cable from somewhere else that receiver will work with PWM. Just get the Grnd, Signal, and +5 lined up correctly and you’re golden.
