Flipsky tft screen
Hi guys I’m back again and I’m just wondering if anyone has purchased the tft screen by flipsky :thinking: any thoughts?
How many beers could 35USD get you? Buy beers instead.
#fuckflipsky
paging @Niklas
His arrived broken, though, or did he get a replacement already?
Ive chosen to get a refund @BillGordon
@Darren_banana this should be enough advise for you ^^ it arrived broke af…
Cheap quality, 10 meters high. Plastic trash.
My humble opinion…
just wanted him to share his experience so that people are aware of some of the pitfalls
Also, if you really can’t resist, buy it on banggood for like 10 dollar less…
Have a look at the OS DAVEGA!
The only issue with it is getting an enclosure
@Darren_banana yes i got one
I need to fix something cause look:
How is it? Why the pic looks so different?
Couldn’t find it on banggood :frowning:
Dyam bruh I aint getting it now hahahaha
I don’t really understand what you mean?
But as you can see, the infos are cropped, it’s a firmware problem, i need to flash another one to see if it any better.
You know what the problem is right?
You have horizontal mode selected, that’s what’s causing the cutoff.
You have to comment it and uncomment vertical mode like this:
I got one for dirt cheap from jinra
I don’t know if it is supported on ACK and I don’t think anyone would care to tell me.
I’m saving it for when I make something besides a esk8 like a drift trike.
@nono_fr
This is what you have now probably:
// Screens. Uncomment the ones you want enabled.
//#define DEFAULT_SCREEN_ENABLED 1
#define SIMPLE_HORIZONTAL_SCREEN_ENABLED 1
//#define SIMPLE_HORIZONTAL_SCREEN_WITH_BATTERY_CURRENT_ENABLED 1
//#define SIMPLE_HORIZONTAL_SCREEN_WITH_MOTOR_CURRENT_ENABLED 1
//#define SIMPLE_VERTICAL_SCREEN_ENABLED 1
//#define SIMPLE_VERTICAL_SCREEN_WITH_BATTERY_CURRENT_ENABLED 1
//#define SIMPLE_VERTICAL_SCREEN_WITH_MOTOR_CURRENT_ENABLED 1
//#define TEXT_SCREEN_ENABLED 1
By taking away the two slashes before the #define you activate a certain mode. You can cycle through them by tapping button 3 I think.
So I would suggest you activate simple vertical.
Should be fixed
Thanks!! I’m going to check my code right now
How do you mount it to your deck?
Btw: does the display show 0 as a value on everything when turned on but not connected ti the VESC? Or will the screen stay black/white
For now i haven’t mounted it on a deck, he’s brand new cause i was searching to sell it…
Yep the screen is as shown on the picture i post, the value are at 0
Could you fix it now? :slight_smile:
So you want to sell it?
I’m actually searching the line of the code to modify, can’t find it atm😅
Well…i’m tempted but i donno if anyone would ne interested, i don’t know if i want to sell it😆
