I was reviving a older build. i stupidly shorted a low voltage conductor to high voltage rail.
can some one provide a high res photo of the 5v capacitors? or let me know the exact capacitor size see photos. looking to repair this.
It’s not exactly the same ESC but the nearby chip layout looks identical, 6.6 plus I think.
There is the same spot
There is like a copy to the side of it if it helps with incomplete numbers.
Hopefully this helps lmk if I should get anything else. This one has holes blasted through it so I could send it to you and you can desolder bits and swap them on. I’ve already cannibalised some large capacitors from it.
appreciate the effort, missleading mouse placement in my one pic.
I’m looking for the orange Tantalum SMD Capacitors.
there are two in parallel for the 5v bus.
low res image from website components circled in red:
Definitely my bad, I should have paid attention to the blown apart bits and not random mouse placement.
I thought they looked like the first digit was a 4 half worn off or something but all the ones on the pcb are absolutely identical.
i thought they used the same ones through out.
thanks a bunch this is so helpful. much appreciated
