Hi all, I need a little of help …
I am using a Flipsky Esc 6.7 70A configured for 12s and max motore amps 50A.
In the winter I never had problems(obviusly…) but with an external temperature of 34 C the esc cut the power when the FET temperature is about 50C degree.
I get the values using the Vesc Tool and real time monitoring.
The problem Is the firmware ?
Thanks for the responses.
whats your temp cutoff set at?
The default value 80C .
whats the motor temp when a cutoff happens?
Sorry, I was busy with my job.
The motors temaind cold.
Maybe this Is the real difference between fsec6.7 mini and fsec6.7 normal wich has more MOSFET .
could be a thermal spike or literally anything. Slap a bigger heatsink on it and see if the problem persists.
Thanks, yes I will try with a bigger hearsink with a BIG fan
Fun fact, when you’re riding your heat sink (if exposed to the outside) is already actively cooled, so a fan is not needed.
Have you had any successful with heatsinks?
