I have a flipsky dual 4.20 plus, this comes with an anti spark switch as well. I am 100% certain this will fail, since it cannot handle the current and many many other users have had similar issues. So I am wondering if there is a way to jump it? So I can use a loop key or other anti spark that is more reliable, such as the fat boy.
I saw this pic on flipsky website, with the 6.6 where you can choose to have a switch or not. Here they seem to have jumped from S to +.
I would have said it as fact if I hadnât actually done it. I wouldâve prefaced with something like âthe manual saysâŠâ.
I have 2 of them, one uses a switch, one doesnât. The one that doesnât has a BMS with E-Switch. I use the E-Switch to control power on/off and roll to start to control the VESC on/off.
I understand, thank you. Would for example having the fatboy anti spark and no switch used in the flipsky work as well as having a bms with an e-switch?
Thank you, all my questions have been sorted out I think the fatboy anitspark is less prone to failure because it is precharging, which the flipsky switch does not.
May I ask how long you have been using the flipsky plus with the switch? Have you had any problems with it?
Around 8 months I think? I havenât had any issues but I use a panel mount to hold the switch and the mount is noted into the enclosure, the switch is completely encased in hot glue inside the enclosure.
MOSFET drain source is shorted with a wire, S and + are shorted while - is left disconnected.
From what Ive heard, Flipsky is working on a smart antispark with roll-to-start and auto-turn-off that employs proper highside switching and inrush current limiting.
One was sent to me by maker-x for for testing but it got lost in transit. Iâm looking for a small anti-spark that wonât fail and so far all the ones Iâve tried haveđ„
On a side note I went on a ride with my friend that you sent one of your prototype Anti Sparks to and did some heavy off roading and it dident even get a tad bit warm! Very impressive!
