Right. That’s what I did. The problem is that all prices then look more expensive than they actually are (if you don’t use PayPal). That kinda sucks since most people don’t decide about purchasing rationally. For some, $99.99 may be an acceptable price while $100 would be too expensive.
It’s gonna get longer, as I need to fit 6 more balance/bleed circuits + depending on if I need to go parallel mosfets for the (at least) 10 Amp charging current capability, as the higher voltage mosfets are usually higher Rds(on) in the same package size. It might also slightly widen to accommodate the square form-factor battery stack monitor IC (LTC6813), unless I do some tricks with the connector layout. Most likely I’ll be able to fit a dedicated connector to the NTC-temperature sensor with the added length.
Otherwise I want to keep it HW feature wise pretty close to the Lite (maybe re-name it to “FlexiBMS Lite 12S” for clarity/distinction between the two designs) apart from supporting up to 18S packs, so the FW stays easily compatible between them and not to divide/fraction the FW development.
Awesome
That’s the only reason why I didn’t bought FlexiBMS - no PayPal
Btw, I’ve sent you an email but got no answer (if a regular bank transfer is possible instead of MasterCard/Visa credit cards)
Now, I’ve also a Metr Pro installed and I was expecting to check the single cells voltage and others parameters as real time charging data. Is it possibile?
