Hi guys. I’ve decided to have a change of direction with my build so repurposing my battery pack to fit in a mate’s Bamboo GT.
It’s going from a 13s4p to become a 10s4p
My question is , my pack was never intended to be flexi BUT I think it will be fine. Do u?
The series connections are made from 12mm x 0.4mm brass strip which is super flexible. (See pics)
Otherwise it’s strip the pack down and use braided wire instead.
Thoughts on a postcard please
Imho it definitely need to swap to silicone wire, you could carefully cut the buss and just solder to it for a quick fix. Just be careful not to pop welds or short it out.
Even though the brass will flex, imho it will put too much strain on the cell welds. Not a lot but it will add up over time and mess something up.
I’ve built a battery for the bamboo GT you’ll need to switch to wires. Also, the GTs enclosure is segmented so you’ll have to break it apart anyways it can’t take a brick pack. Unless you’re using a different enclosure.
