Sorry if this topic is covered in another post. I couldn’t find anything while searching.
I got the 12s4p battery from torque boards and I came with a free enclosure that I believe is made of abs. I’m using a landyachtz switchblade 38 for my build, but due to the shape of the deck, the enclosure doesn’t sit flush. Is it possible to adjust the shape of the enclosure with a heat gun? Any other method? If so does anyone have any tips for doing so?
I saw someone using a metal coat hanger to push on the softened enclosure to make it flush with the deck
But also use a thick joint that you can compress a little, it will make everything waterproof (at an extent) and flush
You might have trouble fitting the battery in if you heat gun and shape it to your deck. There’s not a lot of spare room in it in the battery compartment.
