Can somebody give Mee a idiot explanation how to get the flipsky dual 4.20 to get set up. Help mee
connect the phase wires from the VESC to your motors, connect the power from the battery pack to the VESC, turn on the battery pack power. Do this…
If you are soldering the phase wires, make sure the connectors are fully insulated. So put heatshrink not only over the solder joint, but also the connector itself. An extra step would be to put heatshrink over the connection when you have connected them in your enclosure.
If you have the dual version NOT plus.
DO NOT FLIP THE CAN SWITCH WHILE THE UNIT IS ON
I did this, which ended up with my VESC being completely fried. Here is a picture:
