Hopefully this image will work. I’ve just put together this P45B 12S4P battery and connected the BMS. I’m concerned I’ve done something incorrectly though as when I plugged in the charger it tried to charge for a minute or so (at 0.5amp) then the charger’s light went green and it has given up ever since.
I’ve tested the voltage on all the P groups and they look good, the main battery terminals are showing ~41v, and so is the charging port and the port on the charger.
In the BMS app all the groups are well balanced too.
I did have a fuse between the c- and the charging port previously but removed this in case it was causing an issue but there is no change.
Check the voltages of each pin on the balance connector against ground. The voltage should go up by your pack voltage divided by 12 as you test starting from the blk (B-) to the red on the balance connector.
Also check the voltage and polarity of the charger you have.
The polarity I’m less sure about but the negative side of the xt60 of the charger connects to the negative of the charge port which inturn goes to the C- on the BMS. The positive charger pin connects to the posistive side and goes to the battery positive.
