So I think the time has come for me to start a build thread for my first e-skate. I don’t think there’s anything that I can contribute to this forum as I have f-all experience, but I knew as soon as I found you guys that I wanted to get all your feedback. My intentions for this build were for it to be as cheap as possible, and… well, that’s sort of it. I’m intending to use it for a very short commute, a few days a week for a bit of variety from my ebike and for general cruising.
I figured the deck was a good place to start, so I picked up this used 39" x 9.2" Madrid drop-thru deck, mainly due to the Caliber II’s that were included. I got the seller down to $80 for the complete, which I was happy with considering the board is barely used.
I have the well-beloved (s/) cheapo Lingyi dual ESC. I figured I was never going to push this thing hard and won’t be climbing mountains with it, so I would be okay. From my research, I’ve seen there are 3 generations, with each generation being a bit better than the last, and from what I can tell, I have the 3rd gen. If it fucks out, I’m sure I will be on here hunting for a used VESC.
I also have a pair of 5065 140kv sensored Racerstar motors on their way over. I’ve printed some 36t and 13t pulleys and bought some HTD-255-5M belts to complete my drivetrain. I’ve currently 3D printed some motor mounts, but I have no trust in them and will likely get some machined soon.
The pulleys will be fitted to some 120mm Cloud wheels. I realized how slippery these were once I actually got them and read some reviews, so I may end up looking for a set of something else later on, but like everything else in this build, I think they will do for now.
I bought a 13s2p “100ah” battery from AliExpress… I am keen to see what actually shows up. The enclosure I still need to mock up in CAD, but the plan was to glass it, if it’s even necessary.
The ESC enclosure I have just finished drafting and am in the process of printing. I figured a flexible TPU sleeve would serve me well for waterproofing and shock protection and plan to use some rubber glands for cable passthrough. I plan on routing the battery cable through the drop-through hole or through a hole in the deck directly into the battery enclosure.
It’s dark out, and I can’t be fucked taking images to put up yet, but I’m sure I’ll get to it in the coming days. Hopefully the motors and battery will be here by the end of the month, and I’ll have a complete build to show you guys.
Cheers, Tonks
