Background
This is my first build. I have been hiding in the shadows on the forum a few weeks, reading and trying to learn from others experiences. Now it is time to start my own thread so I have a place to gather my noob questions. Sofar I have derailed @love2scoot build thread with my own question, beause he is working on similar build.
The build design and usage
We have had a Koowheel for a few years but now my son(12) is using that and it is time for me to build myself my own board. Will be fun riding with him as well. Apart from riding for fun I hope to be able to commute to work once in a while.
I have a background in engineering… but havent designed anything for a very long time. Maybe I still know the basics yet. Have built an ebike and some batteries. Better understanding of the theory than real life esk8 implications.
Design philosophy
-Fun to try stuff but when finished it should be reliable
-Based on reliable components
-Build as much as possible myself
-Steer away from “betas”
-Supervised electronics
-Hopefully I can get my son interested in the build and create a “junior” mode so he can try the board when it is fully tested
Components
- List item
Landyachtz Switchblade 40" + eBoosted Enclosure
Torqueboards Direct Drives, 75Kv
Torqueboards 110mm wheels
12s4p 21700 Molicel p40a, 45A
Anti Spark or loop key ???
Esc ??? in the dark about the reliability
BMS, jbd 100A or Bestech D140 charge only
Motors
Back and fort between TB DD 75Kv and eLofty 58Kv. At first I wanted the ability to put AT wheels on but I decided to go with TB DD 75Kv mainly because of reliability.
Battery
I have used Lipos on my ebike build and I really like the power they bring, virtually no sag whatever the load. But this time I wanted something “safer” and “no-brain needed” when charging. But I still wanted a powerful pack with little sag so I went with the p40a 21700 cells, rated at 45A. I am not planning to use more than 100A max so with 4p the cells will probably have a relaxing ride with minimum sag. Want a bluetooth BMS with individual p-cell supervision, preferably both charge/discharge 100A. But havent found anyone that fits yet… Looking on the jbd/llt 80-100A but it is big. Or maybe charge only and Bestech D140. Hoping to get a range of 40km on 12s4p 16Ah. To work and back without charger. Maybe not, anyway no room for more cells.
Esc
Haven’t found the obvious choice here. Want something that runs FOC well. Reliable. UART. Looked at Maker-x, Flipsky. Initial plan was to use Unity but…
Will probably start with Flipsky Anti Spark and prepare for a “loop key” solution if it fails.
At last, half of the components are ordered(but not received) and I am really looking forward to start building. The battery is first in line. I have already found a lot of inspiration on this forum and it is obvious that there is a lot of know-how and experience gathered here. I will of course make my own mistakes but I will also try to learn from yours so good advice will always be appreciated.
Will add pictures as soon as there is something to show.
Longer than intended, Cheers.
