Hello! I would love to take a look at you enclosures! Are you doing any kind of post processing to make the material stronger or weatherproof?
Thank you so much man. I really appreciate the feedback you provided. I updated my list and I would love to have your feedback once again
Thank you for the suggestion. My latest part list is using the ESC you recommended!
Thank you for the info! While Iām a bit concerned with the flex of my board, I think I should be ok with a 3d printed enclosure. Luckily, some people are using the same setup Iām planning. Most of the guess work is done!
Thank you for the feedback! I updated the ESC in my part like for a MakerX
Stark Industries esk8 - Iron Man build (planning) - #73 by moddedlife itāll be strong enough at 100% infill. Iāve 3d printed tire hubs before. Silicone caulking around it. Weatherproof is the material. Abs or petg. DONT use pla
I saw this project before!!! Iām astonished by what other members of this community are able to achieve. Your stuff is truly inspiring man. Thank you for sharing
Idk about inspiring, I havenāt built it yet but thank you
My advice is to to get the helmet, deck, and make your enclosure BEFORE you order the battery or ESCs or basically anything else
I know it sounds weird but if you do that, your build will be better.
Also, if you donāt know what cells are in a battery, donāt buy it. Period. āSamsungā etc. is not a cell, not any more than āFordā is a car make and model.
This man speaks the truth, listen to this golden advice. I did almost the exact same stuff. I thought I was going to make my own enclosures after I had all the stuff. Then I did this
We have spent lots of money collectively to find these things out; if you listen then you donāt have to pay for these same mistakes
Get your enclosure made BEFORE you buy everything else, except the deck and helmet.
If you canāt find an enclosure that matches your deck, you can always consider the fiberglass/resin route.
Itās a nice skill to learn, doesnāt require much tools, doesnāt cost too much money in materials if you do fail, and the best thing is that you can make an enclosure for any deck you want. It might get a bit messy tho and may take time to do.
Your first ones will probably not be the most pretty in the world, but you can always try and remake one later if needed.
I agree with you
However I donāt think an enclosure exists for a 16s10p on a haero lol
I support the 3d printed one as long as itās done right it can last quite a while. Iāve done several at this point. They donāt hold quite as much weight though
