First build done!
Well, here she is. Need to attach the enclosure with shorter screws, but I am pretty much done.
Landyachtz Evo 40 deck
eboosted enclosure and 12s8p battery
Stormcore 60d esc
Davega
Hoyt Puck remote
Flipsky 6384 motors
boardnamics m1 Gear drive
Torqueboard 110mm wheels (might change to onsra 115mm rubbers)
Juma front trucks
Boardnamics rear trucks
bioboards suspension plate
Onsra grip tape tiles
Nice! How’s the motor clearance in the back? Looks a bit tight.
nice to see another board with juma’s :slight_smile: they are really cool
Can post pics later/tomorrow.
Is IS VERY tight indeed but just about fits!
Does that help?
Are you suuure that those aren’t pinching the phase leads? Because it sure looks like it. :smiley: Sickkk board nontheless, can’t wait for your inevitable move to pneumies. :smiley:
Not everyone wants to kill their range :sweat_smile:
Only most :wink:
I angled the cable gland so it would fit without pinching… I think.
(also here you can see the issue with the screws - they are too long but stripped so I need to weld a nut on top to remove and replace them)
also, this board here will not have pneumatic tires.
I have three more boards in progress - two of them will use pneumatics. But it will be a while before they are ready
sweet build! Did you try removing the bushings and move the hanger around by hand to see if it pinches? Also kinda curious, what is the Bioboards suspesion plate?
Looks like this:
Umm… I did not…
(note to self - check this at home lol)
Also, @rusins is correct, these are the ones.
I tried that and… They DO touch, slightly.
crap.
Damn, that sucks! The way I see it you could either reroute the cables more to the sides if they dont get in way of other stuff inside the enclosure. You could also ditch the grommets all toghether, route the cables through the existing holes and just silcone the holes shut. This way you wouldnt have to deal with hassle of filling up those extra holes too.
I guess you could also use a wheel base extender to not deal with any of that stuff alltogether. Its what I did my Century, but my problem was prettty severe motorbite
Other more experienced builders might have better solutions though, I’ve only built one board so far.
I guess I could (and probably will) use these:
They are short enough to provide just enough room for clearence, while not needing any modification done
