Firmware appropriate for FSESC 6.6 DUAL
Hello raiders can someone help me to properly update the fsesc 6.6, I think I have updated it to a version that is not recommended and I should do the downgrade, the manufacturer flipsky recommends not updating above version 5.2, and the vx4 controller I can’t get it to pair
I have last not paid version which Iam using more than 2 years on it and All till now ok. Send me PM. I can share it to You.
Thanks Facko, I have already solved the firmware issue, I have had to downgrade to the factory version 5.2, and install the vesc tool version 5.2. Now I don’t know why the FOC motor detection gives error, and the receiver of the vx4 remote has the red LED light on, I am now solving these new problems
Try conect motor to another side. Friend had fesc 4.2.seconds hand and we tried it 5 or 6 time with switching sides and finally we did it. Probably still some sw issue because of sw change.
Okay, I’m going to try what you say, thank you.
Hope it will help.
I’ve got 6.02 working fine on two of these, but with the integrated power switch. I’ve found the voltage readings fluctuated wildly with 5.2. Dont know what others have found.
Yes true the battery reading fluctuates, but otherwise the version is stable for fsesc6.6. The manufacturer flipsky recommends using factory version 5.2, the firmware of the fsesc and the vesc tool app must match. Thank you for your comment
