I am enjoying my newly built board but I am having trouble with just one thing, brakes.
I’m running a molicel 12s4p with LLT BMS and the guy who built my battery has made it clear that I shouldn’t push more than -40 amps of battery current overall. Sure this sounds fine to me but my problem is super weak brakes.
I’m comparing my current brakes to the extremely powerful Meepo Hurricane brakes which I cannot figure out how to replicate.
Other than the bat, I’m running 6384s 170kv and 2 SkyArtSolos and I have a 15:47 ratio belt drive. Is 15:47 or 170kv the problem here?
What size tire are you running? 3:1 gearing is going to be just OK for acceleration and braking o 6 inch tires. Also, are you talking brakes that stop you dead on hill or braking from 30mph to 0?
If I were in your shoes, check your throttle curve in the VESC remote setting. If that’s where it needs to be, set both sides to -15 for battery regen and -90 to -100 for motors. The battery regen can be an issue but if the -15 isn’t enough, bump it up to -18 then -20. I’m willing to bet it’s because of your motor current. How much do you weight and what’s the battery/esc/motor/gearing and tire size setup?
Edit: just re read and saw you had some of the info I listed, if you can just fill in the gaps… that would be awesome.
6" street pneumatic
I weigh ~150lbs and Im running -20 but for the motor Im still in the -75 range. Am I mistaken in thinking the motor amps are responsible for low end positive and negative acceleration?
No, they play a big roll in low end. Try a little bit of a higher number though and see what you think. It shouldn’t hurt anything if you’re esc can handle it. I think you’ll be pleasantly surprised
