I decided to make a DIY build after riding around on my Zealot and wanting to have the ability for more range, power, and off roading capabilities. I spent around the entire semester waiting on shipping, testing things out and finding parts that work, but it’s finished now finally.
Specs:
MBS comp 95 mountainboard deck
Matrix 3 420m trucks
MBS 8 in tires
12s6p battery
Spintend UBOX V2 100V ESC
dual fs 6384 190kv motors
16-78 ratio w/ 475 mm belts
Went through a lot of revisions with the ESC enclosure since I wanted to design one instead of getting a pelican type case and just cutting a hole in it. Ended up putting it on a mounting plate to add some skate bushings in between the bottom plate of the enclosure and the deck. Might end up swapping the 3d printed top and bottom for the enclosure to be CNC aluminum for better heat dissipation and rigidity.
Uploading: IMG_1982.JPG…
Uploading: IMG_1983.JPG…
Uploading: IMG_1984.JPG…
Uploading: IMG_1985.JPG…
Uploading: IMG_2306.JPG…
Uploading: IMG_2629.JPG…
