Hey can any one recommend some fatter tire rim combos? I’m currently riding rockstar 2 rims with mbs street tire on them. 200x50 and I have 10 mm Axel’s…
Looking for the go-cart looking tire… should I go larger size whats people using these days for tires? Like the look of the meaty pneumatics.
+1 for the mbs xl’s. you can also 3d print spacers to make it even wider if for some reason you need to.
various newbee rims also accommodate wide tires with the option to 3d print a lip for 9in+ tires on their site somewhere.
the linnpower quick release rims will accommodate 6-8in and there is a separate 9in option on their site but idk what changes are made to the rim compared to the 8in ones. you also have to use their pulleys or make custom adapters so might not be the best option.
edit: i would personally go with the mbs xl’s, they’re cheap and they work well, easy to change tires on the fly too
