maybe the wrong category for this but
how bad is the voltage drop under load on the p42a? my 12s pack goes from like 48-49v down the 41v when under load. what is the correct voltage cut off start and end on vesc tool?
12s is fine. But whats the P number is what matters in this case, also how many amps are you pulling at that moment?
12s2p for battery config. running my esc at 30 amps per channel
I think thats pretty normal. At 50A total I am losing about 1.4V in 12s7p with the same cells.
If you are pulling 60A thats 30A per cell that is a lot to ask from a single cell.
i thought 30 amps was pretty standard for these p42a cells
30A is the realistic limit for continuous discharge.
As the chart shows. At 4.0V if you ask 30A from the cell you are losing about 0.7V due to sag. Times 12 thats 8.4 Volts.
The cells can handle current that high (with reduced cycle life) but you’ll get a lot of sag. That’s a verrrrry high power level for a single cell.
I’ll dial it down to 25amps per cell. What is a safe cutoff voltage?
I go 39 and 35. Its slightly aggressive but safe.
Safe? No such thing, there’s always some risk.
But anything over 2.5V/cell is above the low voltage limit, I’d stay over 36V soft limit and 33.6V hard limit though to help extend cell life a little bit.
The higher you go the less range you get but the longer your cells will last…anyways a tradeoff!
