Hey,
Selling some stuff because it doesn’t fit my use anymore and I’m planning on something lighter and less powerfull.
I’m selling a pair of 80100 130kv APS sensorless motors with custom machined axles (machining by APS) stepped from 12 (for 12mm axle support bearing) to 10mm with 4mm keyway and M4 threaded central hole (see drawing below).
They were for a school project, have been assembled on the project but never used or run, they have some scratch marks from moving them around.
They are not battle hardened and might need to be opened and/or blowed out
Also selling an Etoxx Maxi gear drive, Straight cut gears (POM) and axle extenders (should fit on trampa according to the guy I bought it from), They were used by the previous owner, I never even assembled them.
- The plates are a bit bashed up from the previous owner, they come with metal protection plates (that are also a bit bashed up).
- Motor gears are 10mm shaft with 3mm keyway.
- One of the wheel gears is brand new.
- One set of 10 Teeth motor gear and one set of 12 Teeth gear
They seem to fit the 80100 motors but the axles need to be filed/sanded a bit down (I’d say a few 100th mm) to get the gears on. There is a bit of work into making them work together and I do not guarantee that they 100% fit together.
Pricing:
- 250€ for both motors + shipping
- 280€ + shipping for the Etoxx drive and extenders (paid 300 from the previous owner)
- 500€ + shipping for the drives + motors
Also looking for a complete unelectrified Trampa board, so if you have one we can make out something
Only selling both motors together and both drives together
If the price is to high we can discuss it in PM, I can also take more pictures if you need it.
