[EU] [WTB] Big Kegel wheels (TB110 or alike)
I’m looking for some wheels for my eLofty drive with a Kegel adapter. Minimal diameter 110mm. TB110 would be great. I don’t think there are many other options. Or? Maybe the 120mm Flash airless wheels but that’s probably a long shot.
what kv are they? maybe @surfnacho infinity hubs?
They are 54kv but I don’t think anything above 120mm would work well, at least with a 2WD. Torque would be too poor. I tested 150mm airless wheels on the drive and it was very bad.
ah k
guessing cloudwheels are a no cause of core issues? (or was that solved)
AFAIK, cloudwheels are ABEC, not Kegel.
ah yeah your right my bad
also @rusins might have a set of tb110 (dunno though)
You could have a look at the Onsra 115mm rubber wheels. You will have less range than with the TB110 though. They are really comfy, and have unbeatable traction for their size.
One thing to keep in mind, depending on how snug the DD adapter fits into plastic cores, you might need to drill out the cores to have a little bigger diameter pegs. I can only speak for what I have though, my 115s fit quite snugly into the dickyho kegel pressfit/bolt on pulley. If your adapter fits other plastic core kegels very snugly, you might have a problem with these.
I have a set of black TB110s I don’t really need. Almost unused. I already know your address :smiley:
I’ll take the second place in the waiting line… :slightly_smiling_face:
