As E-skating is becoming more and more illegal here in the Netherlands, i’ve decided to regrettably sell the best drivetrain i’ve ever ridden. it comes with used but not trashed Abec11 97mm wheels, Torqueboards wide front truck, custom bushing setup for more stability and the original baseplate is swapped out for a Caliber one.
i’m looking for €375,- for the package, if you want parts separate hit me up
These used to be mine. I didn’t even want to sell them at the time but mees really wanted them and I was looking at belt drives as my next build so he got them.
I don’t have Kegel adapters for them but they’re also quite thick, so 85mm wheels will leave almost no room between drive and street. Imo 97wheels match the best with these drives, as @eskatemanbabes also said.
fun history: This particular Carvon hub motor version was actually a customized KooWheel hub motor set up with the motors moved inward on the hanger and the wheel core adapter bolted onto the end. One of the other things Carvon did was take these hubs and the original KooWheel battery and ESC (which I believe was a ling yi (sp?)) and bolt it all onto a Landyachtz deck but I forget the name of the resulting Carvon board.
The Scheveningen ones were speed drives 110kv. Nice and quiet too but they always overheated after 5 minutes. That’s why I tried the torque drives which were 75kv.
