Hello
I have brroke down my smart bms, i really need one asap… can Somone help?
This one on the picture would be best, just plug and play. Are Open for others aswell. This one would not charge.
picture does not load
There you go my friend
You sure it’s broken?
Yes, the volt on the battery is 39 volt when i check the volt direct to the battery.
But when i check the volt on B- and + on the battery its shows 1,4 volt. I did som stupid shit when i was installing new charging, stupid to install +to - and -to +. And that made it fucked. So it would not charge only balance
What’s the error code it’s giving you?
Undervoltage protection. The problem is that it would not charge, c- and Battery + dont show the right Voltage. The votege on battery is 38 volt without BMS, but with BMS 1,4 volts… Nottingham wrong comes on the app
I would check the voltages on each of the balance terminals first, any lack of connection at that point would give this type of problem.
Could be just a balance wire issue
I firedel it. So battery is safe now.
